주요 콘텐츠로 건너뛰기
ZTE Grand X Max Plus Back Cover Replacement
필요한 것
  1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Back Cover Replacement: 2 단계, 이미지 2개 중 1개 ZTE Grand X Max Plus Back Cover Replacement: 2 단계, 이미지 2개 중 2개
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Back Cover Replacement: 3 단계, 이미지 2개 중 1개 ZTE Grand X Max Plus Back Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully remove the cover from the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jordano Baer
회원 가입일: 10/02/17
716 평판
안내서 5개를 작성함
USF Tampa, Team S9-G4, Remmell Fall 2017 USF Tampa, Team S9-G4, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G4
4 회원들
안내서 10개를 작성함
1가이드 댓글
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
Kiki Jade - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 9
전체 시간: 575
