주요 콘텐츠로 건너뛰기
ZTE Lever Front Camera Replacement
필요한 것
  1. ZTE Lever Front Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Front Camera Replacement: 2 단계, 이미지 1/2 ZTE Lever Front Camera Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Front Camera Replacement: 3 단계, 이미지 1/2 ZTE Lever Front Camera Replacement: 3 단계, 이미지 2/2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Front Camera Replacement: 4 단계, 이미지 1/2 ZTE Lever Front Camera Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Front Camera Replacement: 5 단계, 이미지 1/1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Front Camera Replacement, Front Camera: 6 단계, 이미지 1/2 ZTE Lever Front Camera Replacement, Front Camera: 6 단계, 이미지 2/2
    • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
    • Pry off the plastic cover using the iFixit opening tool.
  7. ZTE Lever Front Camera Replacement: 7 단계, 이미지 1/2 ZTE Lever Front Camera Replacement: 7 단계, 이미지 2/2
    • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
    • Remove the camera from the motherboard.
결론
Eric Lilling
회원 가입일: 10/03/19
169 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 121
