주요 콘텐츠로 건너뛰기
ZTE Lever Power Button Replacement
필요한 것
  1. ZTE Lever Power Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Power Button Replacement: 2 단계, 이미지 2개 중 1개 ZTE Lever Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Power Button Replacement: 3 단계, 이미지 2개 중 1개 ZTE Lever Power Button Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Power Button Replacement: 4 단계, 이미지 2개 중 1개 ZTE Lever Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Power Button Replacement, Volume Buttons: 6 단계, 이미지 1개 중 1개
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Power Button Replacement: 7 단계, 이미지 3개 중 1개 ZTE Lever Power Button Replacement: 7 단계, 이미지 3개 중 2개 ZTE Lever Power Button Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Power Button Replacement: 8 단계, 이미지 2개 중 1개 ZTE Lever Power Button Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Power Button Replacement: 9 단계, 이미지 2개 중 1개 ZTE Lever Power Button Replacement: 9 단계, 이미지 2개 중 2개
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Power Button Replacement, Power Button: 10 단계, 이미지 1개 중 1개
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Power Button Replacement: 11 단계, 이미지 2개 중 1개 ZTE Lever Power Button Replacement: 11 단계, 이미지 2개 중 2개
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
결론
작성자
3다른 기여자 명과 함께
Michael Gonzalez
회원 가입일: 01/29/18
501 평판
안내서 4개를 작성함
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 302
