주요 콘텐츠로 건너뛰기
ZTE Lever Rear Camera Replacement
필요한 것
  1. ZTE Lever Rear Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Rear Camera Replacement: 2 단계, 이미지 1/2 ZTE Lever Rear Camera Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Rear Camera Replacement: 3 단계, 이미지 1/2 ZTE Lever Rear Camera Replacement: 3 단계, 이미지 2/2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Rear Camera Replacement: 4 단계, 이미지 1/2 ZTE Lever Rear Camera Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Rear Camera Replacement: 5 단계, 이미지 1/1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Rear Camera Replacement, Rear Camera: 6 단계, 이미지 1/1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Rear Camera Replacement: 7 단계, 이미지 1/3 ZTE Lever Rear Camera Replacement: 7 단계, 이미지 2/3 ZTE Lever Rear Camera Replacement: 7 단계, 이미지 3/3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Rear Camera Replacement: 8 단계, 이미지 1/2 ZTE Lever Rear Camera Replacement: 8 단계, 이미지 2/2
    • Using a plastic opening tool, disconnect the camera from the motherboard.
  9. ZTE Lever Rear Camera Replacement: 9 단계, 이미지 1/1
    • Remove the camera from the phone.
결론
Michael Gonzalez
회원 가입일: 01/29/18
501 평판
안내서 4개 작성하였습니다
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 6
전체 시간: 110
