주요 콘텐츠로 건너뛰기
ZTE Lever Screen Replacement
필요한 것
  1. ZTE Lever Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Screen Replacement: 2 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Screen Replacement: 3 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Screen Replacement: 4 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Screen Replacement, Volume Buttons: 6 단계, 이미지 1개 중 1개
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Screen Replacement: 7 단계, 이미지 3개 중 1개 ZTE Lever Screen Replacement: 7 단계, 이미지 3개 중 2개 ZTE Lever Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Screen Replacement: 8 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Screen Replacement: 9 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Screen Replacement, Power Button: 10 단계, 이미지 1개 중 1개
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Screen Replacement: 11 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Screen Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Screen Replacement: 14 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Screen Replacement: 16 단계, 이미지 3개 중 1개 ZTE Lever Screen Replacement: 16 단계, 이미지 3개 중 2개 ZTE Lever Screen Replacement: 16 단계, 이미지 3개 중 3개
  17. ZTE Lever Screen Replacement: 17 단계, 이미지 1개 중 1개
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Screen Replacement: 18 단계, 이미지 1개 중 1개
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Screen Replacement: 19 단계, 이미지 3개 중 1개 ZTE Lever Screen Replacement: 19 단계, 이미지 3개 중 2개 ZTE Lever Screen Replacement: 19 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Screen Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the motherboard with your fingers.
  21. ZTE Lever Screen Replacement, Screen: 21 단계, 이미지 2개 중 1개 ZTE Lever Screen Replacement, Screen: 21 단계, 이미지 2개 중 2개
    • Using the iFixit opening tool, pry off the screen from the case.
    • Be careful not to crack the case.
  22. ZTE Lever Screen Replacement: 22 단계, 이미지 3개 중 1개 ZTE Lever Screen Replacement: 22 단계, 이미지 3개 중 2개 ZTE Lever Screen Replacement: 22 단계, 이미지 3개 중 3개
    • Slide the 2 ribbon cables through their respective holes before separating the case from the screen.
    • Gently lift up the case from the screen.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 345
