주요 콘텐츠로 건너뛰기
ZTE Maven 3 Screen Replacement
필요한 것
  1. ZTE Maven 3 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 ZTE Maven 3 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 ZTE Maven 3 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Screen Replacement, Battery: 2 단계, 이미지 3개 중 1개 ZTE Maven 3 Screen Replacement, Battery: 2 단계, 이미지 3개 중 2개 ZTE Maven 3 Screen Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Screen Replacement, Midframe: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Screen Replacement: 5 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Screen Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
  7. ZTE Maven 3 Screen Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
  8. ZTE Maven 3 Screen Replacement: 8 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
  9. ZTE Maven 3 Screen Replacement: 9 단계, 이미지 3개 중 1개 ZTE Maven 3 Screen Replacement: 9 단계, 이미지 3개 중 2개 ZTE Maven 3 Screen Replacement: 9 단계, 이미지 3개 중 3개
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
  10. ZTE Maven 3 Screen Replacement: 10 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
  11. ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: 11 단계, 이미지 2개 중 1개 ZTE Maven 3 Screen Replacement, Daughterboard/Charging Port: 11 단계, 이미지 2개 중 2개
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
  12. ZTE Maven 3 Screen Replacement, Screen: 12 단계, 이미지 1개 중 1개
    • What is left in your hand is now the screen, and any replacement screen will be just as what is in your hand.
결론
작성자
1다른 기여자 명과 함께
Emma Thiboutot
회원 가입일: 10/30/23
705 평판
안내서 8개를 작성함
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 회원
UMASSD-KONN-F23S3G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 187
