주요 콘텐츠로 건너뛰기
ZTE Maven 3 Speaker Replacement
필요한 것
  1. ZTE Maven 3 Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 ZTE Maven 3 Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 ZTE Maven 3 Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Speaker Replacement, Battery: 2 단계, 이미지 1/3 ZTE Maven 3 Speaker Replacement, Battery: 2 단계, 이미지 2/3 ZTE Maven 3 Speaker Replacement, Battery: 2 단계, 이미지 3/3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Speaker Replacement, Midframe: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Speaker Replacement: 4 단계, 이미지 1/1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Speaker Replacement: 5 단계, 이미지 1/2 ZTE Maven 3 Speaker Replacement: 5 단계, 이미지 2/2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Put the midframe on its back and locate the speaker on the bottom left corner.
  7. ZTE Maven 3 Speaker Replacement: 7 단계, 이미지 1/1
    • Gently lift the speaker out of the midframe using your fingers or a tool.
결론
Jalen Castillo
회원 가입일: 10/30/23
135 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 회원
UMASSD-KONN-F23S3G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 17
