소개
Follow this guide to remove and replace the battery for the ZTE Maven.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Carefully, with a pry pick, pry under the battery to cut the adhesive underneath it.
If you are having trouble, apply a heated iOpener onto the battery for another minute, then try again.
You can also apply a few drops of high concentration isopropyl alcohol to the edges of the battery to help soften the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 8개
@gigabit87898 you should consider adding images for each step of any guide. A good guide points out where screws are located, what size they are and if they are all the same etc. It is not enough to write "Remove midframe screws". Remember, guides are written for anybody and keep in mind that people wanting to use your guide to fix their device, may not have your knowledge.
yeah i dont think im going to use a “heat gun” on my battery
As long as you do it correctly, it will be fine.
I have a heat gun, but I think I’ll try a hair dryer first. In the comments under disassembly video at youtube one commenter said the adhesive is just double stick tape. Here’s the video: https://www.youtube.com/watch?v=LY5ltw1X...
Why heat the battery?? I need to change the screen in my moms maven and I'm kinda scared tbh. Lol the protective cover freaks me out!! Help me plzzzz?!?
Heating the battery helps soften the adhesive holding the battery to the case. You definitely don’t need a heat gun. Try prying the battery out without using any heat first. It may just be harder to do, but it is a much safer alternative.
This really makes no sense. I have a ZTE Maven 2 and literally all I would have to do to replace the battery is remove the back cover of the phone, take old battery out, put new battery in, replace back cover of the phone and it would be finished. Replacing the battery on a ZTE Maven 2 is nowhere NEAR as complicated as this article makes it.
AveMaria02 - 답글
Hi AveMaria02,
This guide is for a ZTE Maven 1 (Z812). It is a completely different phone from the Maven 2, as the original Maven has a glued-in battery.
