이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Carefully pry between the screen and midframe to release the clips holding it on.
Carefully, with a pry pick, pry under the battery to cut the adhesive underneath it.
If you are having trouble, apply a heated iOpener onto the battery for another minute, then try again.
You can also apply a few drops of high concentration isopropyl alcohol to the edges of the battery to help soften the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 8개
@gigabit87898 you should consider adding images for each step of any guide. A good guide points out where screws are located, what size they are and if they are all the same etc. It is not enough to write "Remove midframe screws". Remember, guides are written for anybody and keep in mind that people wanting to use your guide to fix their device, may not have your knowledge.
yeah i dont think im going to use a “heat gun” on my battery
As long as you do it correctly, it will be fine.
I have a heat gun, but I think I’ll try a hair dryer first. In the comments under disassembly video at youtube one commenter said the adhesive is just double stick tape. Here’s the video: https://www.youtube.com/watch?v=LY5ltw1X...
Why heat the battery?? I need to change the screen in my moms maven and I'm kinda scared tbh. Lol the protective cover freaks me out!! Help me plzzzz?!?
