주요 콘텐츠로 건너뛰기
ZTE Maven Earpiece Replacement
필요한 것
  1. ZTE Maven Earpiece Replacement, Back Cover: 1 단계, 이미지 1/2 ZTE Maven Earpiece Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use your fingers to remove the back cover.
  2. ZTE Maven Earpiece Replacement, SIM Card: 2 단계, 이미지 1/2 ZTE Maven Earpiece Replacement, SIM Card: 2 단계, 이미지 2/2
    • Remove the SIM card from the right side of the device using a pair of tweezers.
  3. ZTE Maven Earpiece Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
  4. ZTE Maven Earpiece Replacement: 4 단계, 이미지 1/3 ZTE Maven Earpiece Replacement: 4 단계, 이미지 2/3 ZTE Maven Earpiece Replacement: 4 단계, 이미지 3/3
    • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
  5. ZTE Maven Earpiece Replacement, Front Camera: 5 단계, 이미지 1/3 ZTE Maven Earpiece Replacement, Front Camera: 5 단계, 이미지 2/3 ZTE Maven Earpiece Replacement, Front Camera: 5 단계, 이미지 3/3
    • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
    • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
  6. ZTE Maven Earpiece Replacement, Motherboard: 6 단계, 이미지 1/3 ZTE Maven Earpiece Replacement, Motherboard: 6 단계, 이미지 2/3 ZTE Maven Earpiece Replacement, Motherboard: 6 단계, 이미지 3/3
    • Detach the clips and cables and carefully and pull the glue pieces off the sides.
    • Remove the motherboard with your fingers.
  7. ZTE Maven Earpiece Replacement, Earpiece: 7 단계, 이미지 1/2 ZTE Maven Earpiece Replacement, Earpiece: 7 단계, 이미지 2/2
    • Disconnect the earpiece from the screen with tweezers or a spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Toria Keyes
회원 가입일: 10/15/19
207 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 7
전체 시간: 218
