주요 콘텐츠로 건너뛰기
ZTE Maven Motherboard Replacement
필요한 것
  1. ZTE Maven Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 ZTE Maven Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use your fingers to remove the back cover.
  2. ZTE Maven Motherboard Replacement, SIM Card: 2 단계, 이미지 1/2 ZTE Maven Motherboard Replacement, SIM Card: 2 단계, 이미지 2/2
    • Remove the SIM card from the right side of the device using a pair of tweezers.
  3. ZTE Maven Motherboard Replacement, Midframe: 3 단계, 이미지 1/1
    • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
  4. ZTE Maven Motherboard Replacement: 4 단계, 이미지 1/3 ZTE Maven Motherboard Replacement: 4 단계, 이미지 2/3 ZTE Maven Motherboard Replacement: 4 단계, 이미지 3/3
    • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
  5. ZTE Maven Motherboard Replacement, Front Camera: 5 단계, 이미지 1/3 ZTE Maven Motherboard Replacement, Front Camera: 5 단계, 이미지 2/3 ZTE Maven Motherboard Replacement, Front Camera: 5 단계, 이미지 3/3
    • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
    • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
  6. ZTE Maven Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 ZTE Maven Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 ZTE Maven Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Detach the clips and cables and carefully and pull the glue pieces off the sides.
    • Remove the motherboard with your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Karli Kennedy
회원 가입일: 10/15/19
178 평판
안내서 2개 작성하였습니다
댓글 한 개
Is it possible to remove the wifi chip or component. From ZTE Z812 cell. And still be able to use it for talk and text. And if possible where is it located. And how, or where can I have it done, I'm in Houston, Texas. I know it's over kill but that's my question /comment. Thanks for your time.
Damon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 476
