주요 콘텐츠로 건너뛰기
ZTE Prestige 2 Motherboard Replacement
필요한 것
  1. ZTE Prestige 2 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 ZTE Prestige 2 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 ZTE Prestige 2 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Motherboard Replacement: 2 단계, 이미지 1/2 ZTE Prestige 2 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
  3. ZTE Prestige 2 Motherboard Replacement, Back Panel: 3 단계, 이미지 1/3 ZTE Prestige 2 Motherboard Replacement, Back Panel: 3 단계, 이미지 2/3 ZTE Prestige 2 Motherboard Replacement, Back Panel: 3 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Motherboard Replacement: 4 단계, 이미지 1/3 ZTE Prestige 2 Motherboard Replacement: 4 단계, 이미지 2/3 ZTE Prestige 2 Motherboard Replacement: 4 단계, 이미지 3/3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the three 3 mm Phillips #00 screws on the edges of the motherboard.
  6. ZTE Prestige 2 Motherboard Replacement: 6 단계, 이미지 1/3 ZTE Prestige 2 Motherboard Replacement: 6 단계, 이미지 2/3 ZTE Prestige 2 Motherboard Replacement: 6 단계, 이미지 3/3
    • Use the iFixit opening tool to dig under the sticker where the volume and the power buttons are located on both sides.
  7. ZTE Prestige 2 Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the curved tweezers to gently remove the black cable running down the left side of the device and disconnect it from its socket.
  8. ZTE Prestige 2 Motherboard Replacement: 8 단계, 이미지 1/3 ZTE Prestige 2 Motherboard Replacement: 8 단계, 이미지 2/3 ZTE Prestige 2 Motherboard Replacement: 8 단계, 이미지 3/3
    • Use the curved tweezers to then unlock each of the ZIF connectors and pull the cables out.
    • The motherboard should now be able to fully disconnect from the rest of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maria Stock
회원 가입일: 01/31/20
524 평판
안내서 5개 작성하였습니다
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 195
