소개
If your ZTE Quest phone can't hold a charge or you're having trouble turning on your phone, then this guide will provide instructions on how to replace your battery.
필요한 것
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
