주요 콘텐츠로 건너뛰기
ZTE Quest n817 Daughterboard Replacement
필요한 것
  1. ZTE Quest n817 Daughterboard Replacement, Battery: 1 단계, 이미지 1/3 ZTE Quest n817 Daughterboard Replacement, Battery: 1 단계, 이미지 2/3 ZTE Quest n817 Daughterboard Replacement, Battery: 1 단계, 이미지 3/3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Daughterboard Replacement: 2 단계, 이미지 1/2 ZTE Quest n817 Daughterboard Replacement: 2 단계, 이미지 2/2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Daughterboard Replacement, Daughterboard: 3 단계, 이미지 1/1
    • Carefully pry open the back panel with the plastic opening tool.
  4. ZTE Quest n817 Daughterboard Replacement: 4 단계, 이미지 1/1
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
  5. ZTE Quest n817 Daughterboard Replacement: 5 단계, 이미지 1/1
    • Remove the two 2.0mm screws on either side of the daughterboard.
  6. ZTE Quest n817 Daughterboard Replacement: 6 단계, 이미지 1/1
    • Remove the coaxial connector that links the daughterboard to the motherboard.
결론
Eric Loureiro
회원 가입일: 10/26/18
582 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 255
