주요 콘텐츠로 건너뛰기
ZTE Quest n817 Motherboard Replacement
필요한 것
  1. ZTE Quest n817 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 ZTE Quest n817 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 ZTE Quest n817 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Motherboard Replacement: 2 단계, 이미지 1/2 ZTE Quest n817 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Motherboard Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Motherboard Replacement: 7 단계, 이미지 1/1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Motherboard Replacement: 8 단계, 이미지 1/2 ZTE Quest n817 Motherboard Replacement: 8 단계, 이미지 2/2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
결론
Eric Loureiro
회원 가입일: 10/26/18
582 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 507
