이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you do need to replace your ZTE Quest's motherboard, this guide will take you through the process of opening your device and fully removing the motherboard.
필요한 것
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
거의 끝나갑니다!
결론
