이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If your ZTE Quest's power and/or volume buttons aren't working properly then it may be necessary to replace them. This guide requires extensive soldering knowledge and should really only be attempted as a last resort.
필요한 것
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
Each of these buttons can be removed using micro-soldering techniques around either side of the button.
Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
다른 한 분이 해당 안내서를 완성하였습니다.
