주요 콘텐츠로 건너뛰기
ZTE Speed Front and Back Camera Replacement
필요한 것
  1. ZTE Speed Front and Back Camera Replacement, Front and Back Camera: 1 단계, 이미지 1/2 ZTE Speed Front and Back Camera Replacement, Front and Back Camera: 1 단계, 이미지 2/2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Front and Back Camera Replacement: 2 단계, 이미지 1/2 ZTE Speed Front and Back Camera Replacement: 2 단계, 이미지 2/2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Front and Back Camera Replacement: 3 단계, 이미지 1/2 ZTE Speed Front and Back Camera Replacement: 3 단계, 이미지 2/2
    • With the plastic opening tool the spudger, gently pry off the inner back seal around the phone.
    • Be careful not to pry it off too harsh, as it is just plastic.
  4. ZTE Speed Front and Back Camera Replacement: 4 단계, 이미지 1/2 ZTE Speed Front and Back Camera Replacement: 4 단계, 이미지 2/2
    • With the spudger, gently pry off camera at the top-middle of the phone to get back camera.
    • With the spudger, gently pry off camera at the top-left of the phone to get the front camera.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Garrett Barry
회원 가입일: 03/04/16
722 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 UMass Dartmouth, Team 6-3, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 320
