주요 콘텐츠로 건너뛰기
ZTE Speed Headphone Jack Replacement
필요한 것
  1. ZTE Speed Headphone Jack Replacement, Motherboard: 1 단계, 이미지 1/2 ZTE Speed Headphone Jack Replacement, Motherboard: 1 단계, 이미지 2/2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Headphone Jack Replacement: 2 단계, 이미지 1/2 ZTE Speed Headphone Jack Replacement: 2 단계, 이미지 2/2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Headphone Jack Replacement: 3 단계, 이미지 1/2 ZTE Speed Headphone Jack Replacement: 3 단계, 이미지 2/2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Headphone Jack Replacement: 5 단계, 이미지 1/3 ZTE Speed Headphone Jack Replacement: 5 단계, 이미지 2/3 ZTE Speed Headphone Jack Replacement: 5 단계, 이미지 3/3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Headphone Jack Replacement: 6 단계, 이미지 1/2 ZTE Speed Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Carefully take off motherboard.
  7. ZTE Speed Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 1/2 ZTE Speed Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 2/2
    • Flip over motherboard to locate headphone jack circuit.
결론
Garrett Barry
회원 가입일: 03/04/16
722 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 UMass Dartmouth, Team 6-3, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 246
