주요 콘텐츠로 건너뛰기
ZTE Telstra T95 SIM Card Replacement
  1. ZTE Telstra T95 SIM Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 SIM Card Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 SIM Card Replacement, SIM Card: 3 단계, 이미지 1개 중 1개
  4. ZTE Telstra T95 SIM Card Replacement: 4 단계, 이미지 1개 중 1개
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 SIM Card Replacement: 5 단계, 이미지 2개 중 1개 ZTE Telstra T95 SIM Card Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jeesenia Rios
회원 가입일: 10/25/14
300 평판
안내서 2개를 작성함
Gateway, Team 1-1, Johnson Fall 2014 Gateway, Team 1-1, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G1
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 1,010
