주요 콘텐츠로 건너뛰기
ZTE Tempo Front Camera Replacement
필요한 것
  1. ZTE Tempo Front Camera Replacement, Front Camera: 1 단계, 이미지 1/3 ZTE Tempo Front Camera Replacement, Front Camera: 1 단계, 이미지 2/3 ZTE Tempo Front Camera Replacement, Front Camera: 1 단계, 이미지 3/3
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Front Camera Replacement: 2 단계, 이미지 1/3 ZTE Tempo Front Camera Replacement: 2 단계, 이미지 2/3 ZTE Tempo Front Camera Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Camera Replacement: 3 단계, 이미지 1/2 ZTE Tempo Front Camera Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
    • Lift the front camera out of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dela Mohammed
회원 가입일: 10/18/18
135 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 139
