주요 콘텐츠로 건너뛰기
ZTE Tempo Front Screen Assembly Replacement
필요한 것
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: 1 단계, 이미지 1/2 ZTE Tempo Front Screen Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: 2 단계, 이미지 1/3 ZTE Tempo Front Screen Assembly Replacement: 2 단계, 이미지 2/3 ZTE Tempo Front Screen Assembly Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: 3 단계, 이미지 1/3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: 3 단계, 이미지 2/3 ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: 3 단계, 이미지 3/3
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: 5 단계, 이미지 1/2 ZTE Tempo Front Screen Assembly Replacement: 5 단계, 이미지 2/2
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: 6 단계, 이미지 1/3 ZTE Tempo Front Screen Assembly Replacement: 6 단계, 이미지 2/3 ZTE Tempo Front Screen Assembly Replacement: 6 단계, 이미지 3/3
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
결론
다른 2명이 해당 안내서를 완성하였습니다.
omar
회원 가입일: 10/02/18
717 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 303
