주요 콘텐츠로 건너뛰기
ZTE Tempo Rear Camera Replacement
필요한 것
  1. ZTE Tempo Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/2 ZTE Tempo Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2/2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Rear Camera Replacement: 2 단계, 이미지 1/2 ZTE Tempo Rear Camera Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  3. ZTE Tempo Rear Camera Replacement: 3 단계, 이미지 1/2 ZTE Tempo Rear Camera Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
omar
회원 가입일: 10/02/18
717 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 153
