주요 콘텐츠로 건너뛰기
ZTE Tempo X Charging/Aux Board Replacement
필요한 것
  1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: 1 단계, 이미지 1/2 ZTE Tempo X Charging/Aux Board Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Charging/Aux Board Replacement, Battery: 2 단계, 이미지 1/2 ZTE Tempo X Charging/Aux Board Replacement, Battery: 2 단계, 이미지 2/2
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: 3 단계, 이미지 1/2 ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: 3 단계, 이미지 2/2
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  4. ZTE Tempo X Charging/Aux Board Replacement: 4 단계, 이미지 1/2 ZTE Tempo X Charging/Aux Board Replacement: 4 단계, 이미지 2/2
    • Take off the second back cover, lifting from the bottom of the device to the top.
  5. ZTE Tempo X Charging/Aux Board Replacement: 5 단계, 이미지 1/3 ZTE Tempo X Charging/Aux Board Replacement: 5 단계, 이미지 2/3 ZTE Tempo X Charging/Aux Board Replacement: 5 단계, 이미지 3/3
    • Using a spudger, unclip the board from the phone at the places highlighted.
  6. ZTE Tempo X Charging/Aux Board Replacement: 6 단계, 이미지 1/3 ZTE Tempo X Charging/Aux Board Replacement: 6 단계, 이미지 2/3 ZTE Tempo X Charging/Aux Board Replacement: 6 단계, 이미지 3/3
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
결론
Conager Robb
회원 가입일: 09/21/18
592 평판
안내서 5개 작성하였습니다
University of North Texas, Team S5-G2, Thompson Fall 2018 University of North Texas, Team S5-G2, Thompson Fall 2018 회원
UNT-THOMPSON-F18S5G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 213
