메인 콘텐츠로 스킵하기
소개
Use this guide to replace the volume buttons on your ZTE Tempo X.
부품
지정된 부품이 없습니다.
  1. Remove back cover using the divot provided. Remove back cover using the divot provided.
    • Remove back cover using the divot provided.
  2. Find the divot near the bottom of the battery and remove the battery from the device. Find the divot near the bottom of the battery and remove the battery from the device.
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Using a Phillips #00 screwdriver, remove the sixteen 3 mm screws holding the back panel in place. Remove the back panel. Remove the back panel.
    • Using a Phillips #00 screwdriver, remove the sixteen 3 mm screws holding the back panel in place.
    • Remove the back panel.
  5. To remove the volume keys, pull them away from the phone. The keys will slide out from their set position. Be aware of the edges of the phone when removing the keys. Be aware of the edges of the phone when removing the keys.
    • To remove the volume keys, pull them away from the phone. The keys will slide out from their set position.
    • Be aware of the edges of the phone when removing the keys.
결론
Conager Robb
회원 가입일: 2018년 09월 21일
592 평판
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 80
