주요 콘텐츠로 건너뛰기
ZTE Whirl 2 Speaker Replacement
필요한 것
  1. ZTE Whirl 2 Speaker Replacement, Battery: 1 단계, 이미지 1/3 ZTE Whirl 2 Speaker Replacement, Battery: 1 단계, 이미지 2/3 ZTE Whirl 2 Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. ZTE Whirl 2 Speaker Replacement: 2 단계, 이미지 1/3 ZTE Whirl 2 Speaker Replacement: 2 단계, 이미지 2/3 ZTE Whirl 2 Speaker Replacement: 2 단계, 이미지 3/3
    • Pry the battery from the phone using your fingers.
  3. ZTE Whirl 2 Speaker Replacement, Back Panel: 3 단계, 이미지 1/3 ZTE Whirl 2 Speaker Replacement, Back Panel: 3 단계, 이미지 2/3 ZTE Whirl 2 Speaker Replacement, Back Panel: 3 단계, 이미지 3/3
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. ZTE Whirl 2 Speaker Replacement: 4 단계, 이미지 1/3 ZTE Whirl 2 Speaker Replacement: 4 단계, 이미지 2/3 ZTE Whirl 2 Speaker Replacement: 4 단계, 이미지 3/3
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. ZTE Whirl 2 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the midframe from the digitizer.
  6. ZTE Whirl 2 Speaker Replacement, Speaker: 6 단계, 이미지 1/2 ZTE Whirl 2 Speaker Replacement, Speaker: 6 단계, 이미지 2/2
    • Use tweezers to remove the lock button and volume stickers from the phone.
    • The volume buttons peel off much like a sticker.
  7. ZTE Whirl 2 Speaker Replacement: 7 단계, 이미지 1/1
    • Use a tweezers to lift the lock from the ZIF connector above the camera. Pull the ribbon from the connector.
    • The ribbon is connected by a lock. Flip the lock up to unlatch the ribbon with a set of tweezers.
  8. ZTE Whirl 2 Speaker Replacement: 8 단계, 이미지 1/2 ZTE Whirl 2 Speaker Replacement: 8 단계, 이미지 2/2
    • Use a tweezers to lift the lock from the ZIF connector. Pull the ribbon from the connector.
    • Like the camera ribbon, it has a latch that you need to flip to unlock.
  9. ZTE Whirl 2 Speaker Replacement: 9 단계, 이미지 1/1
    • Pull the speaker from the phone by using a pair of tweezers.
    • The speaker has a sticky like back, it peels easiest with a tweezers.
결론
Alana Rucks
회원 가입일: 02/04/20
461 평판
안내서 4개 작성하였습니다
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 74
