주요 콘텐츠로 건너뛰기
ZTE Z667T Speaker Replacement
필요한 것
  1. ZTE Z667T Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Gently insert your fingernail into the bottom left crevice of the back cover and lift up.
  2. ZTE Z667T Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the battery by inserting your fingernail at the top of the battery and lift up.
  3. ZTE Z667T Speaker Replacement: 3 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the five screws located on the back case.
  4. ZTE Z667T Speaker Replacement: 4 단계, 이미지 1/1
    • Gently pry open the back case using the plastic opening tool.
    • Pry open in multiple locations to avoid damage.
  5. ZTE Z667T Speaker Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool, gently lift the speaker out of the back case.
결론
Michael Lidbetter
회원 가입일: 02/12/18
121 평판
안내서 1개 작성함
Washington State, Team S2-G1, Lobnitz Spring 2018 Washington State, Team S2-G1, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S2G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 149
