소개
This is not a guide for replacing the switch assembly, only for replacing the plastic covers to the buttons.
부품
부품은 필요하지 않습니다.
  1. Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. Remove the battery with an opening tool or fingernail.
    • Remove the battery with an opening tool or fingernail.
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
결론
Julian Mendoza
회원 가입일: 2018년 09월 21일
698 평판
안내서 5개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 24
전체 시간: 60
