주요 콘텐츠로 건너뛰기
ZTE ZMAX Z970 Battery Replacement
필요한 것
  1. ZTE ZMAX Z970  Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 ZTE ZMAX Z970  Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970  Battery Replacement: 2 단계, 이미지 2개 중 1개 ZTE ZMAX Z970  Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970  Battery Replacement: 3 단계, 이미지 3개 중 1개 ZTE ZMAX Z970  Battery Replacement: 3 단계, 이미지 3개 중 2개 ZTE ZMAX Z970  Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970  Battery Replacement: 4 단계, 이미지 2개 중 1개 ZTE ZMAX Z970  Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970  Battery Replacement: 5 단계, 이미지 2개 중 1개 ZTE ZMAX Z970  Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970  Battery Replacement: 6 단계, 이미지 2개 중 1개 ZTE ZMAX Z970  Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Burak Cengiz
회원 가입일: 02/15/18
480 평판
안내서 4개를 작성함
USF Tampa, Team S17-G3, Boczar Spring 2018 USF Tampa, Team S17-G3, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G3
3 회원들
안내서 10개를 작성함
1가이드 댓글
Although I haven’t yet embarked on this task, I feel more confident in doing so successfully. I have watched the Youtube videos on this and none of them showed such things as the number and placement of the screws. They did give some idea as to the difficulty of it however.
Please continue to produce more of these instructional blurbs.
aikidoronin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 1,838
