주요 콘텐츠로 건너뛰기
ZTE ZMAX Z970 Volume Button Replacement
필요한 것
  1. ZTE ZMAX Z970 Volume Button Replacement, Battery: 1 단계, 이미지 1/2 ZTE ZMAX Z970 Volume Button Replacement, Battery: 1 단계, 이미지 2/2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Volume Button Replacement: 2 단계, 이미지 1/2 ZTE ZMAX Z970 Volume Button Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Volume Button Replacement: 3 단계, 이미지 1/3 ZTE ZMAX Z970 Volume Button Replacement: 3 단계, 이미지 2/3 ZTE ZMAX Z970 Volume Button Replacement: 3 단계, 이미지 3/3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Volume Button Replacement: 4 단계, 이미지 1/2 ZTE ZMAX Z970 Volume Button Replacement: 4 단계, 이미지 2/2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Volume Button Replacement: 5 단계, 이미지 1/2 ZTE ZMAX Z970 Volume Button Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Volume Button Replacement: 6 단계, 이미지 1/2 ZTE ZMAX Z970 Volume Button Replacement: 6 단계, 이미지 2/2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Volume Button Replacement, Volume Button: 7 단계, 이미지 1/2 ZTE ZMAX Z970 Volume Button Replacement, Volume Button: 7 단계, 이미지 2/2
    • Peel off circuit board carefully.
    • The new part will need to be soldered onto the motherboard.
결론
Burak Cengiz
회원 가입일: 02/15/18
480 평판
안내서 4개 작성하였습니다
USF Tampa, Team S17-G3, Boczar Spring 2018 USF Tampa, Team S17-G3, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 333
