주요 콘텐츠로 건너뛰기
ZTE ZMax Pro Back Panel Assembly Replacement
필요한 것
  1. ZTE ZMax Pro Back Panel Assembly Replacement, Back Panel Assembly: 1 단계, 이미지 1개 중 1개
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Back Panel Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Back Panel Assembly Replacement: 3 단계, 이미지 2개 중 1개 ZTE ZMax Pro Back Panel Assembly Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Back Panel Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Back Panel Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Back Panel Assembly Replacement: 6 단계, 이미지 2개 중 1개 ZTE ZMax Pro Back Panel Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Back Panel Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Back Panel Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Mihir Deshmukh
회원 가입일: 04/18/18
405 평판
안내서 1개를 작성함
Cal Poly, Team S17-G3, Livingston Spring 2018 Cal Poly, Team S17-G3, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G3
4 회원들
안내서 16개를 작성함
1가이드 댓글
When I tried this at step 8 the screen peeled off instead of the top cover. Ruined my phone.
Solomon Martinez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 14
전체 시간: 1,049
