소개
This guide will show you how to replace the charging port. You will need a plastic opening tool, tweezers, and a Phillips #00 screwdriver.
필요한 것
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
Use tweezers to peel off the tape at the bottom of the phone.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 11개
Very nice BUT where do you get the replacement charging port?
Where can I bye the parts
“Buy” as in purchase not “Bye” as in see you later.
How much is it cost to fix it
My charging port was 5.79 with free shipping at
James T. -
The info below is how this seller/item is posted on Amazon. The price I previously posted is incorrect. The corrected amount is/was $6.97 with no shipping via prime membership!
↓↓↓↓↓↓ *As shown on Amazon posting* ↓↓↓↓↓↓
PHONSUN USB Charging Sync Data Type-C Port Charger Dock Connector for ZTE ZMAX PRO Z981
James T. -
Very well put together guide. Completed the task in about 5 min. Now all I have to do is find a reputable store or sight to get a new board from. Any suggestions?
I've ordered my replacement parts through Amazon. Specifically the seller I buy from has yet to let me down. They always ship quickly, without error, and the parts are good quality. The 1st and only time I've had difficulty, they promptly replaced the part no questions asked!
Best of luck going forward!
James
Email: James.oratrat.jt@gmail.com
James T. -
James
My charging port is soldered to the mother board. ZTE light pro v9 ,different from the one depicted. Good instructions though,
My charging port is soldered to the mother board. The port fell off the mother board. Difficult to see the connection ,
ZTE pro light v9. Regards.
