소개
This guide will show you how to replace the power button on your device. You will need a plastic opening tool, tweezers, and a Phillips #00 screwdriver.
필요한 것
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
Use the plastic opening tool to remove the lower left connector on the motherboard.
다른 5명이 해당 안내서를 완성하였습니다.
