소개
The viewfinder assembly includes the button board, I/O ports, buttons, and viewfinder. Replace all of them in one fell swoop with a new viewfinder assembly.
필요한 것
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Remove the following four screws securing the back cover of the camera housing:
two silver 8.5 mm screws,
two black 8.8 mm screws.
Peel back the Kapton tape covering the viewfinder assembly ribbon cable connector on the motherboard.
Use the tip of a spudger to flip up the retaining flap on the viewfinder assembly ribbon cable ZIF connector.
다른 한 분이 해당 안내서를 완성하였습니다.
