주요 콘텐츠로 건너뛰기
Zeal Optics iON Viewfinder Lens Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Zeal Optics iON Viewfinder Lens Assembly Replacement, Viewfinder Lens Assembly: 1 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement, Viewfinder Lens Assembly: 1 단계, 이미지 2/2
    • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
    • Flip the viewfinder housing over 180 degrees.
    • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
  2. Zeal Optics iON Viewfinder Lens Assembly Replacement: 2 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement: 2 단계, 이미지 2/2
    • Pull the two halves of the viewfinder housing apart.
  3. Zeal Optics iON Viewfinder Lens Assembly Replacement: 3 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement: 3 단계, 이미지 2/2
    • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Be sure to pry up on the hinged flap, not the connector itself.
  4. Zeal Optics iON Viewfinder Lens Assembly Replacement: 4 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement: 4 단계, 이미지 2/2
    • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
  5. Zeal Optics iON Viewfinder Lens Assembly Replacement: 5 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement: 5 단계, 이미지 2/2
    • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
  6. Zeal Optics iON Viewfinder Lens Assembly Replacement: 6 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement: 6 단계, 이미지 2/2
    • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
  7. Zeal Optics iON Viewfinder Lens Assembly Replacement: 7 단계, 이미지 1/2 Zeal Optics iON Viewfinder Lens Assembly Replacement: 7 단계, 이미지 2/2
    • Remove the viewfinder lens assembly from the viewfinder housing.
결론
Eric Flores
회원 가입일: 07/31/12
128 평판
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 243
