이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
이 단계에 사용된 도구:Tweezers$4.99-
Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
