소개
"I can see clearly now…oh wait, no I can't. Where am I?"
Having trouble seeing the viewfinder in your Zeal Optics iON goggles? The viewfinder lens could be scratched or cracked, so use this guide to replace it.
필요한 것
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
Pull the viewfinder lens off of the viewfinder LCD.
Remove the rubber O-ring from the viewfinder lens.
The viewfinder lens remains.
