주요 콘텐츠로 건너뛰기
Zebra ZP 505 Peel and Present System Replacement
필요한 것
  1. Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: 1 단계, 이미지 1/2 Zebra ZP 505 Peel and Present System Replacement, Peel and Present System: 1 단계, 이미지 2/2
    • Orient the printer so that the bottom is facing up.
    • Remove the three P1 9mm screws located on the bottom of the printer and remove the lower unit.
  2. Zebra ZP 505 Peel and Present System Replacement: 2 단계, 이미지 1/2 Zebra ZP 505 Peel and Present System Replacement: 2 단계, 이미지 2/2
    • Remove the P0 9mm screw.
    • Proceed to remove the cover.
  3. Zebra ZP 505 Peel and Present System Replacement: 3 단계, 이미지 1/1
    • Disconnect the harness.
    • Thread the harness through the hole on the right hand side.
  4. Zebra ZP 505 Peel and Present System Replacement: 4 단계, 이미지 1/1
    • Remove the peel and present system by utilizing a metal spudger.
  5. Zebra ZP 505 Peel and Present System Replacement: 5 단계, 이미지 1/1
    • Remove the peel and present system.
결론
Brian Jagger
회원 가입일: 09/27/17
316 평판
안내서 3개 작성하였습니다
Cal Poly, Team S8-G2, Banghart Fall 2017 Cal Poly, Team S8-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 772
