주요 콘텐츠로 건너뛰기
Zeepad 7DRK Battery Replacement
필요한 것
  1. Zeepad 7DRK Battery Replacement, Battery: 1 단계, 이미지 1/2 Zeepad 7DRK Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Begin the process by prying off the back of the Zeepad using the opening tool.
    • Start by edging the corner of the opening tool into the edge of the device and work your way from there until the back cover is removed.
  2. Zeepad 7DRK Battery Replacement: 2 단계, 이미지 1/1
    • Once the back casing has been removed, identify the location of the battery inside the device, marked with the red circle.
  3. Zeepad 7DRK Battery Replacement: 3 단계, 이미지 1/3 Zeepad 7DRK Battery Replacement: 3 단계, 이미지 2/3 Zeepad 7DRK Battery Replacement: 3 단계, 이미지 3/3
    • Identify the pieces of tape holding the battery to the back of the screen, and peel them off to remove them.
  4. Zeepad 7DRK Battery Replacement: 4 단계, 이미지 1/3 Zeepad 7DRK Battery Replacement: 4 단계, 이미지 2/3 Zeepad 7DRK Battery Replacement: 4 단계, 이미지 3/3
    • Locate the connection between the battery and motherboard, and disconnect it by pulling the two apart.
  5. Zeepad 7DRK Battery Replacement: 5 단계, 이미지 1/3 Zeepad 7DRK Battery Replacement: 5 단계, 이미지 2/3 Zeepad 7DRK Battery Replacement: 5 단계, 이미지 3/3
    • To finally finish removing the battery, the two wires connecting to it must be separated.
    • Peel back the tape covering the origin of the wires.
    • Finally, remove the two metal connectors attached to the green piece from the battery with a tug.
    • The battery has now been successfully removed.
결론
Alexandra Souza
회원 가입일: 10/20/16
222 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 631
