주요 콘텐츠로 건너뛰기
Zeepad 7DRK LED Screen Replacement
필요한 것
  1. Zeepad 7DRK LED Screen  Replacement, LED Screen: 1 단계, 이미지 1/3 Zeepad 7DRK LED Screen  Replacement, LED Screen: 1 단계, 이미지 2/3 Zeepad 7DRK LED Screen  Replacement, LED Screen: 1 단계, 이미지 3/3
    • First, pry off the outer yellow casing using the blue plastic prying tool provided in the kit.
    • Wedge the flat edge of the pry tool in the slit and use leverage to push the casing upwards and pop it off in multiple places across the top and side of the device.
    • This should reveal the inner workings of the tablet, be careful as the volume and power buttons may fall out in the process. The speaker will also still be attached to the case by wires as shown.
  2. Zeepad 7DRK LED Screen  Replacement: 2 단계, 이미지 1/3 Zeepad 7DRK LED Screen  Replacement: 2 단계, 이미지 2/3 Zeepad 7DRK LED Screen  Replacement: 2 단계, 이미지 3/3
    • Once the casing is off, carefully pull the speaker out of its plastic holding slot, be careful not to separate the connections to the wires.
  3. Zeepad 7DRK LED Screen  Replacement: 3 단계, 이미지 1/3 Zeepad 7DRK LED Screen  Replacement: 3 단계, 이미지 2/3 Zeepad 7DRK LED Screen  Replacement: 3 단계, 이미지 3/3
    • Next, remove the 4 screws that hold the mother board in place. Allowing the motherboard to wiggle in place.
  4. Zeepad 7DRK LED Screen  Replacement: 4 단계, 이미지 1/3 Zeepad 7DRK LED Screen  Replacement: 4 단계, 이미지 2/3 Zeepad 7DRK LED Screen  Replacement: 4 단계, 이미지 3/3
    • Now that the motherboard is disconnected, disconnect the longer flat cables by pushing the locks open and taking the cable out.
  5. Zeepad 7DRK LED Screen  Replacement: 5 단계, 이미지 1/3 Zeepad 7DRK LED Screen  Replacement: 5 단계, 이미지 2/3 Zeepad 7DRK LED Screen  Replacement: 5 단계, 이미지 3/3
    • First, peel the clear yellow tape off to detach the battery from different wires and the metal.
    • Next, peel the battery off the double sided tape to remove it from the metal.
    • Both the battery and and the motherboard will still be attached to some wires, these wires are soldered connections, do your best to avoid breaking these connections.
  6. Zeepad 7DRK LED Screen  Replacement: 6 단계, 이미지 1/3 Zeepad 7DRK LED Screen  Replacement: 6 단계, 이미지 2/3 Zeepad 7DRK LED Screen  Replacement: 6 단계, 이미지 3/3
    • Use the metal prying tool to remove the metal casing from around the LED screen
    • Replace the screen
결론
다른 한 분이 해당 안내서를 완성하였습니다.
William Strickland
회원 가입일: 10/20/16
143 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G8
3 회원들
안내서 10개 작성하였습니다
댓글 2개
Where did you or can I buy the replacement screen. Please email response to PhillipsT052163@gmail.com.
Thank You & God Bless!
Theresa Phillips
Theresa Phillips - 답글
where and how do i get this replacement screen for the zeepad 7dr-q
steven Neville - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 563
