주요 콘텐츠로 건너뛰기
Zeepad 7DRK Power and Volume Button Replacement
필요한 것
  1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: 1 단계, 이미지 1/1
    • First find the power and volume buttons so that you are familiar with their location.
    • The smaller button is the power button and the larger button is the volume button.
  2. Zeepad 7DRK Power and Volume Button  Replacement: 2 단계, 이미지 1/2 Zeepad 7DRK Power and Volume Button  Replacement: 2 단계, 이미지 2/2
    • To open the tablet, use one of the soft-tip prying tools.
    • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
  3. Zeepad 7DRK Power and Volume Button  Replacement: 3 단계, 이미지 1/1
    • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
    • This is what the tablet looks like when pried apart.
  4. Zeepad 7DRK Power and Volume Button  Replacement: 4 단계, 이미지 1/2 Zeepad 7DRK Power and Volume Button  Replacement: 4 단계, 이미지 2/2
    • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
    • In the second picture, the volume control button is shown. Again notice the small locator rings.
  5. Zeepad 7DRK Power and Volume Button  Replacement: 5 단계, 이미지 1/2 Zeepad 7DRK Power and Volume Button  Replacement: 5 단계, 이미지 2/2
    • Now remove the old or broken buttons, and replace them.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trevor Taylor
회원 가입일: 10/20/16
234 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 343
