주요 콘텐츠로 건너뛰기
Zeepad 7DRK Speaker Replacement
필요한 것
  1. Zeepad 7DRK Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Zeepad 7DRK Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Begin by popping off the plastic yellow device casing with the soft tip prying tool.
    • Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
  2. Zeepad 7DRK Speaker Replacement: 2 단계, 이미지 1/2 Zeepad 7DRK Speaker Replacement: 2 단계, 이미지 2/2
    • Once the device is opened, the speaker should fall out of its position.
    • Follow the red and black wires attached to the speaker to find the location of connection.
  3. Zeepad 7DRK Speaker Replacement: 3 단계, 이미지 1/1
    • The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
    • Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
결론
Alexandra Souza
회원 가입일: 10/20/16
222 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-8, Martin Fall 2016 UMass Dartmouth, Team 6-8, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 92
