주요 콘텐츠로 건너뛰기
Zeki TBQG884B Camera Replacement
필요한 것
  1. Zeki TBQG884B Camera Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Zeki TBQG884B Camera Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: 3 단계, 이미지 2개 중 1개 Zeki TBQG884B Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: 4 단계, 이미지 2개 중 1개 Zeki TBQG884B Camera Replacement, Camera: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Natalie Holm
회원 가입일: 09/16/15
146 평판
안내서 1개를 작성함
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S1G3
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 9
전체 시간: 391
