주요 콘텐츠로 건너뛰기
Zenithink ZTPAD ZT280 C91 Back Panel Replacement
필요한 것
  1. Zenithink ZTPAD ZT280 C91 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Back Panel Replacement: 2 단계, 이미지 1/3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: 2 단계, 이미지 2/3 Zenithink ZTPAD ZT280 C91 Back Panel Replacement: 2 단계, 이미지 3/3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicholas Davis
회원 가입일: 09/21/18
345 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 152
