주요 콘텐츠로 건너뛰기
Zenithink ZTPAD ZT280 C91 Camera Replacement
필요한 것
  1. Zenithink ZTPAD ZT280 C91 Camera Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the two screws on the bottom using a Phillips #00 screwdriver.
    • For differentiation purposes, these screws are 4mm long.
  2. Zenithink ZTPAD ZT280 C91 Camera Replacement: 2 단계, 이미지 1/3 Zenithink ZTPAD ZT280 C91 Camera Replacement: 2 단계, 이미지 2/3 Zenithink ZTPAD ZT280 C91 Camera Replacement: 2 단계, 이미지 3/3
    • Using a spudger, start prying the case apart by working around the edge slowly.
    • Be careful not to damage any of the latches that hold the back panel in place, especially if you are using a metal spudger.
    • While prying, be careful to not lose the power and volume buttons; the case is the only thing holding them in place so they will easily come out once the panel has been removed
    • Be careful to not damage the speaker cables, they will still be connecting both panels.
  3. Zenithink ZTPAD ZT280 C91 Camera Replacement, Motherboard: 3 단계, 이미지 1/1
    • Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
  4. Zenithink ZTPAD ZT280 C91 Camera Replacement: 4 단계, 이미지 1/1
    • Flip up the small gate and unplug the ribbon cable shown.
  5. Zenithink ZTPAD ZT280 C91 Camera Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the screws highlighted with the orange rings as shown in the picture.
    • For differentiation purposes, these screws are 3.5mm long.
  6. Zenithink ZTPAD ZT280 C91 Camera Replacement: 6 단계, 이미지 1/1
    • Slide back the plastic latch for the main display cable.
    • Carefully unplug the cable with tweezers.
  7. Zenithink ZTPAD ZT280 C91 Camera Replacement: 7 단계, 이미지 1/2 Zenithink ZTPAD ZT280 C91 Camera Replacement: 7 단계, 이미지 2/2
    • Slide back the plastic latch for the camera cable.
  8. Zenithink ZTPAD ZT280 C91 Camera Replacement: 8 단계, 이미지 1/1
    • Peel back the reflective tape.
  9. Zenithink ZTPAD ZT280 C91 Camera Replacement: 9 단계, 이미지 1/2 Zenithink ZTPAD ZT280 C91 Camera Replacement: 9 단계, 이미지 2/2
    • Lift up the motherboard assembly, starting by lifting up the top.
    • Be careful not to damage any of the ports on the underside of the tablet.
    • The camera cable will slide through a small notch and end up underneath the board.
  10. Zenithink ZTPAD ZT280 C91 Camera Replacement, Camera: 10 단계, 이미지 1/1
    • Peel back the adhesive tape holding the camera in place.
    • Remove the camera from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Keelie Beach
회원 가입일: 09/21/18
435 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 130
