이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
In the process of disconnecting the motherboard you will begin with taking off 4 screws with a phillips screwdriver. Once that is done you should be careful with disconnecting all the cables connected to the board, making sure you don't tear any of the wires.
필요한 것
Peel back the touch interface chip (which is on the top right of the motherboard, covered in yellow tape.)
다른 2명이 해당 안내서를 완성하였습니다.
