소개
If your Zerodate T26 mouse has a broken scroll wheel or a scroll wheel that is too dirty to clean without disassembly, then this step-by-step guide on the replacement of the scroll wheel is for you! All you need is a simple plastic opening tool to pry the top and a Phillips #00 screwdriver to remove the plates. Replacement scroll wheels can be ordered online.
필요한 것
Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
다른 한 분이 해당 안내서를 완성하였습니다.
