주요 콘텐츠로 건너뛰기
Zipper Stop Replacement
필요한 것
  1. Zipper Stop Replacement, Stop: 1 단계, 이미지 1/1
    • Evaluate the damage and examine the zipper for any indications of fracture, misalignment, or looseness.
  2. Zipper Stop Replacement: 2 단계, 이미지 1/1
    • Align the zipper stop so the post is on the same side as the zipper slider.
  3. Zipper Stop Replacement: 3 단계, 이미지 1/1
    • Gently place the stop beneath the zipper teeth.
  4. Zipper Stop Replacement: 4 단계, 이미지 1/2 Zipper Stop Replacement: 4 단계, 이미지 2/2
    • After the stop has been positioned appropriately, clamp it in place with the needle nose pliers.
    • To ensure a snug fit, use firm pressure at multiple points to clamp the stop tightly around the zipper teeth.
  5. Zipper Stop Replacement: 5 단계, 이미지 1/1
    • To make sure the stop is firmly attached to the zipper track, gently tug on it after clamping it. Reclamp the stop if needed.
결승점
Dejia P.
회원 가입일: 02/20/24
121 평판
안내서 1개 작성함
CSU Sacramento, Team 1-1, Laflen Spring 2024 CSU Sacramento, Team 1-1, Laflen Spring 2024 회원
CSUSAC-LAFLEN-S24S1G1
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 60
전체 시간: 86
