주요 콘텐츠로 건너뛰기
Zippo Lighter Felt Pad and Cotton Replacement
필요한 것
  1. Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 1 단계, 이미지 1/3 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 1 단계, 이미지 2/3 Zippo Lighter Felt Pad and Cotton Replacement, Felt Pad and Cotton: 1 단계, 이미지 3/3
    • Open the lid of the lighter.
    • Hold the bottom of the lighter’s case and pull out the metal container.
    • Set the case aside for now.
  2. Zippo Lighter Felt Pad and Cotton Replacement: 2 단계, 이미지 1/2 Zippo Lighter Felt Pad and Cotton Replacement: 2 단계, 이미지 2/2
    • Turn the metal container upside down with the bottom facing you.
    • You should see a piece of white felt with the words “Lift to fill.”
  3. Zippo Lighter Felt Pad and Cotton Replacement: 3 단계, 이미지 1/2 Zippo Lighter Felt Pad and Cotton Replacement: 3 단계, 이미지 2/2
    • Loosen the screw with a flathead screwdriver.
    • There is a spring behind the screw, so make sure you are unscrewing slowly and gently.
    • Remove the screw with the spring and the flint attached to it.
  4. Zippo Lighter Felt Pad and Cotton Replacement: 4 단계, 이미지 1/2 Zippo Lighter Felt Pad and Cotton Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift the felt pad up and out of the metal container using a pair of tweezers.
  5. Zippo Lighter Felt Pad and Cotton Replacement: 5 단계, 이미지 1/2 Zippo Lighter Felt Pad and Cotton Replacement: 5 단계, 이미지 2/2
    • Use a pair of tweezers to remove the old cotton from the inside.
    • When adding new cotton, it should fully cover the inside of the metal canister.
    • Throw the old felt and cotton in the garbage.
  6. Zippo Lighter Felt Pad and Cotton Replacement: 6 단계, 이미지 1/3 Zippo Lighter Felt Pad and Cotton Replacement: 6 단계, 이미지 2/3 Zippo Lighter Felt Pad and Cotton Replacement: 6 단계, 이미지 3/3
    • Use a pair of tweezers to push each cotton piece on top of the wick inside the metal container. Make sure the cotton pieces cover all the sides.
  7. Zippo Lighter Felt Pad and Cotton Replacement: 7 단계, 이미지 1/1
    • Use a pair of tweezers to place the new felt pad on top of the cotton pieces.
  8. Zippo Lighter Felt Pad and Cotton Replacement: 8 단계, 이미지 1/2 Zippo Lighter Felt Pad and Cotton Replacement: 8 단계, 이미지 2/2
    • Replace the flint and screw it back into place using a flathead screwdriver.
  9. Zippo Lighter Felt Pad and Cotton Replacement: 9 단계, 이미지 1/2 Zippo Lighter Felt Pad and Cotton Replacement: 9 단계, 이미지 2/2
    • Refuel your lighter, put the metal container back inside the case, and test out the lighter.
    • Only use the lighter when it is secured inside the case.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Dara
회원 가입일: 10/01/21
193 평판
안내서 1개 작성함
York University, Team G-35, O'Regan Fall 2021 York University, Team G-35, O'Regan Fall 2021 회원
YORK-O'REGAN-F21SGG35
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 188
전체 시간: 8,835
