주요 콘텐츠로 건너뛰기
Zoiinet AK1 Smart Switch Battery Replacement
필요한 것
  1. Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Mount from Wall: 1 단계, 이미지 1개 중 1개
    • Dislodge the switch mounting plate from the wall (if applicable -- you may have adhesive on the back or basic screws)
  2. Zoiinet AK1 Smart Switch Battery Replacement, Eject the Rocker Switch: 2 단계, 이미지 1개 중 1개
    • Gently press on the rocker switch from the back of the plate, it should easily pop out.
  3. Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Switch Plate from Hinges: 3 단계, 이미지 2개 중 1개 Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Switch Plate from Hinges: 3 단계, 이미지 2개 중 2개
    • Using either an iFixit pick or fingernail gently pull apart from the middle of the switch on one side. The switch face should pop off its hinge.
  4. Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Inner Plate: 4 단계, 이미지 2개 중 1개 Zoiinet AK1 Smart Switch Battery Replacement, Dislodge Inner Plate: 4 단계, 이미지 2개 중 2개
    • There is an inner plastic plate held in place by 8x plastic tabs (2 on each side). Inset the iFixit pick into each pair, gently wedging/rotating in until the tabs are blocked for 2 or 3 sides. The inner plate should come loose
    • Note: There is an up arrow indicating the "on" portion of the switch. This matches an arrow on the back of the rocker switch from the previous step
  5. Zoiinet AK1 Smart Switch Battery Replacement, Remove Membrane & Circuit Board: 5 단계, 이미지 1개 중 1개
    • The silicon membrane sits loosely atop the circuit board and the CR2032 battery within. Lift both out.
  6. Zoiinet AK1 Smart Switch Battery Replacement, Replace the Battery: 6 단계, 이미지 2개 중 1개 Zoiinet AK1 Smart Switch Battery Replacement, Replace the Battery: 6 단계, 이미지 2개 중 2개
    • Use a small screwdriver, pen, or iFixit opener tool and press from the underside of the battery compartment to slide the old battery up and out.
    • Insert a new CR2032 battery from the top, the positive (+) side should face you
  7. Zoiinet AK1 Smart Switch Battery Replacement, Reassemble + Test: 7 단계, 이미지 1개 중 1개
    • Restore the circuit board and membrane to the inner housing. If all is functional, the On button at the top (up arrow) should flash a green LED when the circuit connects.
결론
You're done! Congratulations!
작성자
1다른 기여자 명과 함께
Repair4Lyfe
회원 가입일: 08/23/25
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 44
